27.03.2018, 05:40
In many applications we have different requirements for Light trigger, Sound detection, etc.
Light Magnet Contactor is one of the solutions. It has to work with light sensor to activate the magnetic switch.
ModelContact FormContact PowerSize(mm)Specialty(Contacts)
GlassDiameterFull length
ORD2131A1W7.0maxφ1.80max35.8 ± 0.3Super Mini(Rh)
ORD213S1A1W7.0maxφ1.80max13Super Mini SMD(Rh)
ORD2111A1W10.0maxφ2.0max35.7±0.3Mini(Rh)
ORD2191A10W12.0maxφ2.00max44.3 ± 0.3Common Mini(Rh)
ORD2211A10W13.0maxφ2.30max44.2 ± 0.3Mini Flat(Rh)
ORD22211A10W13.0maxφ2.30max56.7 ± 0.3Mini Contact Long Contact(Rh)
ORD228VL1A10W14.0maxφ2.20max44.3 ± 0.3Mini(Rh)
ORD228S-11A10W14.0maxφ2.20max19.6 ± 0.3Mini(Rh)
ORD22201A10W14.0maxφ2.20max56.7 ± 0.3Mini Wide(Rh)
ORD2291ADC50W/AC70W21.0maxφ2.75max55.4 ± 0.3High Voltage&Power (Rh)
ORD22101ADC50W/AC70W21.0maxφ2.75max55.4 ± 0.3High Power (Rh)
ORD2210V1A100W21.0maxφ2.75max55.4 ± 0.3Vacuum Voltage&Power(Rh)
ORD22111A50W(12V-3.4)16.5maxφ2.80max44.1 ± 0.3LED style(Rh)
ORD22121A10W16.5maxφ2.80max43.9 ± 0.3Closed Value(Rh)
ORD2341A10W21.0maxφ3.50max43.4 ± 0.3Long life(Rh)
ORD92151A10W17.0maxφ2.80max44.1 ± 0.5Mini(Rh)
ORD92161A10W14.0maxφ2.20max44.3 ± 0.5Mini(Rh)
ORT5511C3W14.0maxφ2.54maxN.O51.6 ± 0.3Super Mini COM(Rh)
N.C56.1 ± 0.3
ORD3111A10W7.0maxφ1.80max35.8 ± 0.3Life Super Mini(lr)
ORD3121A30W12.0maxφ2.00max44.3 ± 0.3Power/Life(lr)
RA-9011A10W2.5±0.2(W)2.5±0.2(H)19.5±0.2(L)Mini SMD(Finished)
RA-9031A1.0W2.1±0.2(W)2.1±0.2(H)12.3±0.2(L)Mini SMD(Finished)
Here you can have your ideas come true for the Inductive Switch, Position Switch, Magnet Contactor, Electromagnetic Switch, Relay Switch etc. There are professional team and workers ready for you. Please contact us without hesitation.
Magnet Contactor manufacturers
website:http://www.cianswitch.com/magnet-contactor/
N.C56.1 ± 0.3
